It is currently Fri 22. Nov 2024 12:52:46
PostPosted: Mon 01. Apr 2019 20:59:52
So I did 3 flights yesterday and when I went to use the hard deck (alt limit with recovery) it just took off up , up and up it went till I knew something was wrong and flipped the switch back. Went to check the logs after and found this. Anyone else ever have this problem? it was working just fine awhile ago. anyways here are some screen shots and logs..
spirit-log-2019-03-31-140035.pdf [74.84 KiB]
Downloaded 82 times
spirit-log-2019-03-31-141908.pdf [73.2 KiB]
Downloaded 97 times
spirit-log-2019-03-31-144434.pdf [65.33 KiB]
Downloaded 83 times
Downloaded 83 times
Downloaded 83 times
Downloaded 83 times
Users browsing this forum: No registered users and 14 guests
