Spirit System
"Soft Handing Over" from collektive Pitch at Rescue
https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=2337
Author:  threeDfreak [ Sat 09. Dec 2017 14:10:35 ]
Post subject:  "Soft Handing Over" from collektive Pitch at Rescue
i have a question if possible to add.
The following example.
I fly backwards with my Heli and have much negative collektive Pitch on the Stick. Now i push Rescue Normal and the FBL push the Heli in Horizont with Gear down. The collektive Pitch at Rescue is handled from the FBL. It push the Heli first negative and then positive as in the settings adjusted.
When now the Rescue Funktion procedure is over the FBL give the collektive Pitch back to the Pilot. But at this moment the collektive Pitch from the Pilot is still full negative because he was flying backwards before Rescue.
On other FBL Systems the collektive Pitch will be "Soft Handed Over" (in about 1-2sec time from the positive Rescue Position to the Position from the Pilot Sticks). The Pilot can feel and see that he is still at full negative Pitch and can correct his Stick Position without surprise and stress. In my opinion this is really much more comfortable in the Rescure Situation than the hard handle over to full Negative Pitch.
Is is possible to add this?
Thank you very much :D
Author:  thestructured [ Mon 22. Jan 2018 12:13:06 ]
Post subject:  Re: "Soft Handing Over" from collektive Pitch at Rescue
this is actually a really neat idea.
Author:  threeDfreak [ Mon 22. Jan 2018 12:58:08 ]
yes, it is difficult to explain. At another Flybarsystem the Setup is explained and done like in the pic.
http://www.phpbb.com/
