Chanel mapping in Spirit https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=1994 |
Page 1 of 1 |
Author: | Windsurfer1976 [ Sat 27. May 2017 23:04:46 ] |
Post subject: | Chanel mapping in Spirit |
Hi Thomas, im using a hott system with Gr-16 receiver and a mz-24 Sender. As i use the sumd connection all channels are used by the system (Gyro, bank Switch included). I would like to use more than 8 channels on my gr-16 as i use the sumd connection (i need few more for led controller). But there is a issue with the channel mapping. The channels 8-12 can only be used by special functions. It would be great if it will be possible to map the bank switching or gyro sens on chanels 8-12. Then i could use the free ports on my gr-16 via mapping to control my led controller. Hope u understand my problem Greetings Andreas |
Author: | ZeXx86 [ Sun 28. May 2017 10:50:28 ] |
Post subject: | Re: Chanel mapping in Spirit |
Hi, you may try to remap the channels in your receiver. This should be possible with GR-16 if I am not wrong. Thank you for your suggestion! |
Author: | Windsurfer1976 [ Mon 29. May 2017 22:12:25 ] |
Hi Thomas, thank you for your reply but this is not possible. If I map chanel 9 to port 1 then it goes through sumd on chanel 1. If I could select gyro gain or bank switch to chanel 9 - 12 it would work.... Greetings Andreas Gesendet von meinem SM-G800F mit Tapatalk |
Author: | ZeXx86 [ Tue 30. May 2017 8:22:48 ] |
Thank you for the details. I believe it will be possible to implement it in the future updates. |
Author: | Windsurfer1976 [ Tue 30. May 2017 21:30:20 ] |
Thank you Thomas Gesendet von meinem SM-G800F mit Tapatalk |
