It is currently Fri 22. Nov 2024 7:38:02
 Post subject: [SOLVED] Manual error
PostPosted: Mon 01. May 2017 9:30:30
Hi Tomáš,
I found a small error in the manual, all the uSpirit pictures in Wiring say "PWM".
One question also: if Ele/Pit/Ail became Pit/Ele/Ail this most probably also impacts RPM sensor wiring so there should be different pictures there also.
 Post subject: Re: Manual error
PostPosted: Mon 01. May 2017 9:35:16
The manual is in development right now. So it will be corrected.
Thank you for your help!
