It is currently Fri 22. Nov 2024 6:57:51
PostPosted: Sat 18. Feb 2017 20:06:32
As I read many people have problems to connect ESC to the Spirit and get it working.
It would be fine to get detailed informations on Hobbywing, castle, etc
PostPosted: Sat 18. Feb 2017 20:14:56
thank you. We will try to improve it.
But there is only one way how you can connect the ESC to the unit.
Just plug the ESC to the AUX port and thats all. It is same for each ESC.
Then go to the General/Channels and assign Channel 1 to the Throttle function. From this point everything should work.
PostPosted: Mon 20. Feb 2017 19:36:52
It might be that it seems easy for you to assign Channel 1 for the Throttle function, but I got in channel collision.
From my point of view in the BD it is to connect the ESC to the unit.
All leads (gas and BEC) you have to connect to the unit and that is all....
Users browsing this forum: No registered users and 40 guests
