It is currently Fri 22. Nov 2024 7:09:51
PostPosted: Wed 18. Jan 2017 0:01:50
Current Spirit Profile Beta prints "Servos ‐> Subtrim ‐> Pitch (CH1)" value of "66" while the value is actually "-66" in software "Spirit Settings v2.2.0".
Used to work fine at least until 19-DEC.
PostPosted: Wed 18. Jan 2017 21:12:21
Thank you for the message.
We will check it. The software (Spirit Settings) is doing a special reversing depending on the servo reverses, but in case of the viewer it is displaying a raw values (unmodified).
PostPosted: Wed 18. Jan 2017 21:29:37
http://4dsviewer.spirit-system.com/www/ ... ?_fid=cq8w
http://4dsviewer.spirit-system.com/www/ ... ?_fid=wdui
For both files, Spirit Software actually shows -66, while the 4dsviewer shows -66 in the first (older) and 66 in the second (newer).
Nothing actually changed in my setup, as far as I know... I went through the setup to redo the servo adjustments after replacing a broken link but in the end I ended up with the same -66 value of adjustment.
PostPosted: Wed 18. Jan 2017 21:38:01
Thank you very much.
This is really interesting.
I will move the thread to the Wishlist / Bug report section.
PostPosted: Wed 18. Jan 2017 21:56:50
I forgot to say that it's probably not a problem of the viewer, since both files are now viewed with the same version of viewer...
PostPosted: Wed 18. Jan 2017 22:00:52
We will verify it tommorow and let you know. It might be related with profile loading/saving.
