[SOLVED] Governor: Gear Ratio to small for larger Scalers https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=1659 |
Page 1 of 1 |
Author: | SnakeEyes [ Fri 23. Sep 2016 8:40:05 ] |
Post subject: | [SOLVED] Governor: Gear Ratio to small for larger Scalers |
Hi, I just found out that the gear ratio in governor settings is limited to 1:12.7. Gear ratio of the HSM800 mechanic is 1:13.83. And thats not the only one beyond that limit. That means I can't use the Spirit Pro governor properly because I can't set it up correctly. Please increase that range! Best regards, Thomas |
Author: | ZeXx86 [ Fri 23. Sep 2016 11:14:56 ] |
Post subject: | Re: Governor: Range of Gear Ratio to small for larger Scaler |
Hi, We will fix the problem soon. Right now you can use workaround that will work in the same way as if you enter the correct value. You can simply change Sensor divider. Governor is using this only for RPM calculation, which is evaulated by Gear Ratio * Sensor divider. If the result will be similar with other sensor divider and gear ratio, then result is the same. Let's say you have Gear Ratio 4. 4 * 13.83 = 55,32 5 * 11,05 = 55,25 This mean that 11,05 ratio will give you same result as with 13,85. |
Author: | SnakeEyes [ Fri 23. Sep 2016 12:07:46 ] |
Thank you very much, that will do for me! |
