It is currently Fri 22. Nov 2024 9:01:09
[ 2 posts ] |
phil.d.basket
Posted: Tue 14. Jun 2016 6:29:26 |
During initialization the cyclic pitch pump cadence, three quick movements, is identical regardless of the status of the unit, i.e. if there are no errors all cyclic servo arms will rapidly move three times (a short-short-short cadence: S-S-S) and if there are errors, one cyclic servo arm* will rapidly move three times - with the same S-S-S cadence. As a result, it's not possible to determine any status information from the pump cadence.
It would be easier for users to distinguish between these two pump sequences if they had a different cadence, e.g. the no-error state could retain the S-S-S cadence and the problem state could use a simple up-down servo arm movement with a short-short cadence (S-S).
This concept could be extended by adding pump codes with the S-S error prefix to help distinguish between warning events and the four major error events, e.g.
Warnings: S-S // two short movements Receiver Signal Lost: S-S-L-L // two short followed by two long movements Main Loop Hang: S-S-L-L-L // two short & three long movements Power Voltage Low: S-S-L-L-L-L Vibration Level Very High: S-S-L-L-L-L-L
The unit is aware of what faults have been diagnosed, a small revision would enable it to communicate this information to the user.
I hope this is helpful,
Phil
*note: it would be helpful if the distinction between the error-free state and the major problem state pitch pump movement was detailed in the User Guide, e.g. on p. 34 of the english version 2.0.1.
Last edited by phil.d.basket on Wed 22. Jun 2016 18:50:00, edited 3 times in total.
Adrian
Posted: Tue 21. Jun 2016 20:26:19 |
Joined: Thu 08. Oct 2015 14:43:12 Posts: 204 Location: Switzerland
+1, would help a lot. I would like to see led blinking representing current bank.
_________________ Oxy4max SpiritPro + HW // SOXOS 550, SpiritPro, HW120A V4, 920KV // SOXOS 600, SpiritPro, HW160A, Pyro650 // SOXOS Strike7, SpiritPro, HW160A, Pyro750 // Skywing Spirit Aero // FrSky Horus X10S + Taranis X7 /
[ 2 posts ] |
Users browsing this forum: No registered users and 8 guests |
