It is currently Mon 25. Nov 2024 7:16:26
PostPosted: Sun 31. Jan 2016 17:56:11
Dear Spirit Team
I would like to see the possibility to assign a permanent active stabi Mode to specific Bank.
Use case:
I like to fly Bank 0 / 1 with gyro gain from TX (adjust for different rpm) and use negative gain to select rescue acro.
While I use Bank 2 on teacher setup in Stabilization Mode with my little kids.
Currently on my DX9 I have to work with lots of mixers on different activation as well as limiting max range on Gyro channel.
Implementation: Bank 0/1 inverting Gyro with two mixers, by activating rescue switch. 2x (GER->GYR -100% / 0 / active on A I)
If Bank 2 is selected, inverting Gyro permanent, by Activation on Switch E Position 2 (my Bank Switch)
But by pushing Rescue Button A while running on Bank 2, negative value gets doubled, I had to limit gyro range under Servos Setting to not over gain rudder, causing oscillation.
As you see, there is allays a workaround, but requested functionality would make things a lot easier to switch in between different Stabi modes.
As these Stabi Modes really work great on Spirit, I would like to see improvements on ease of use.
All required would be a tick-box in Stabi mode tab to select it permanent or on negative Gyro Gain.
Please reply, if you think this would be useful as well.
PostPosted: Sun 31. Jan 2016 23:22:07
+1
And it should actually be quite easy to implement by allowing negative values in the Rudder common gain...
PostPosted: Mon 04. Apr 2016 10:19:50
I'm picking up this again.....
As I'm using my Copter for teaching newbies and for my own fun, I would like to have:
Bank (0) for Teaching first hoover => Stabi Coax permanent (neg Gyro)
Bank (1) for Teaching Basics => Stabi Normal permanent (neg Gyro)
Bank (2) for 3D => Rescue on Demand (pos Gyro, neg on Panic Button)
Well this can be achieved with advanced Mixers in TX changing Gain based on Bank selector, things would be a lot easier if preset could be selected in Stabi.
Cooco suggested negative Gain, this would do perfect and I like it, but for most users to hard to understand. Changing Common Gain in Sensor-Tap to invert Stabi activation...
1) I suggest a selector in Stabi where user can select "Active on neg Gyro Value" or "Active on positiv Gyro Value"
2) I also suggest an indication, if Stabi is currently active of not. Think of Coax or Scale where activation on ground can hardly be seen.
Users browsing this forum: No registered users and 9 guests
