It is currently Fri 22. Nov 2024 12:56:22
[ 3 posts ] |
jjuk
Posted: Tue 12. Feb 2019 17:46:12 |
Can we get "Geometry 6° (tuning)" moved to the "Limits" tab, below cyclic ring? It's a essential required step of the setup and therefore should not really be an advanced setting.
I think maybe "auto-rotation bailout time" should be moved to the Governor settings tab.
Posted: Wed 13. Feb 2019 11:54:02 |
thank you for your message.
Geometry 6° is in the Advanced tab, because once you will set it with the Setup Wizard you should really not change it. Only in cases when you know what you are doing a changes are needed. For this reason it is just for those that know implications of changing it. Also the parameter is not considered as a Limit.
jjuk
Posted: Wed 13. Feb 2019 12:07:13 |
I change it every time i crash and break servo arms as the servo arm position and link lengths change each time.
[ 3 posts ] |
Users browsing this forum: No registered users and 24 guests |
