mb-1953 wrote:
I am using the Castle governor not the governor featured in the Spirit. The castle governor is fed information on the motor kv and the gearing.
I did calibrate the ESC, I have many of these and am familiar with the process.
Sorry to post it in the wrong location.
Just to be sure, is this what you did?
a) changed your TX Throttle Curve to 0-25-50-75-100
b) modified your TX end points so that the Spirit Diagnostic screen shows 0% at min stick and 100% at max stick
c) set the ESC in Fixed-Endpoints and calibrated by acting on Min and Max of Spirit Governor screen
d) set the ESC in Governor Mode and configured appropriately (and changed your TX Throttle Curves to flat 30%, flat 70%, flat 100%)
Is it?
