Spirit System
Collective trim
https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=1060
Author:  Alyon187 [ Wed 25. Nov 2015 20:54:42 ]
Post subject:  Collective trim
Could yall incorporate a collective trim option for when setting up the head? The way its setup now you have to make sure your horns are perfectly level at 90 w the pushrod. For setups that aren't perfect it would be great to use a collective trim to help raise or lower the swash all together so that once you level the swash and install the head you dont have to take it all off again to get the blades to line up. If im not making sense look at how vbar does their swash setup, theres tabs to raise all the servos at once as well as individually.
Author:  Coco66 [ Wed 25. Nov 2015 21:40:24 ]
Post subject:  Re: Collective trim
You can already do it in Servo subtrim, just move the three servos the same amount.
Although, that's not the proper proper proper way to do it...
http://www.phpbb.com/
