It is currently Thu 21. Nov 2024 19:40:21
 Post subject: Geolink Altitude Limit
PostPosted: Tue 12. Jul 2022 11:08:26
Is it possible to have a delay or buffer for the Alt Limit? I assume you need to be climbing when engaging the feature? Tried setting it in the hover and it went straight into Rescue. Thanks!!
PostPosted: Tue 12. Jul 2022 11:13:57
This is intentional behavior so that you know when you will engage the rescue and that it really works.
After this initial rescue it will work and rescue again when model will drop under level where it was activated initially.
Also if rescue was not active and you forgot, it can save your model similarly as normal rescue.
PostPosted: Tue 12. Jul 2022 11:40:30
Thanks Tomas, if that's how it is then I'll modify my engagement.
Users browsing this forum: No registered users and 20 guests
