It is currently Thu 21. Nov 2024 19:17:49
PostPosted: Fri 21. Jan 2022 0:25:07
I'm not sure if this was ever discussed...
Is it possible to use Tribunus Telemetry (I'm using a number of 14-200) in VBar mode? Currently to use the telemetry you have to set it to 'Tele Uni' mode in Tribunus. However this has a major downside
- the only way you can connect to the Tribunus with your smartphone or laptop, is in 1 sec after it's powered up. Later, the tele-uni takes over and you can't connect to it. Which also means you can't get any data after flight.
If Spirit would use same protocol as Vbar (and don't get me wrong, I strongly prefer Spirit), we could leave default settings in Tribunus and connect to it all the time. And maybe also - in future - change its settings?
Users browsing this forum: No registered users and 17 guests
