It is currently Fri 22. Nov 2024 1:26:39
PostPosted: Wed 09. Sep 2020 15:21:16
I have a Spirit 2 using SRXL2 with Geolink + IX12
I have enough channels to turn on different control rescue and RTH.
RTH turned on, heli goes at the right spot
Rescue is on a toggle switch and will go up and after the delay, controls are given back.
When i turn on RTH and toggle rescue, the Heli will go up and never stop until i turn off rescue. did wait the timeout and tried it a few times with the same results.
Here are the config file.
File comment: Bank 2
2.4ds [255 Bytes]
Downloaded 75 times
File comment: Bank 1
1.4ds [255 Bytes]
Downloaded 60 times
File comment: Bank 0
0.4ds [255 Bytes]
Downloaded 75 times
PostPosted: Sat 12. Sep 2020 12:45:32
Hi Thomas,
What should I expect in terms of follow up on this issue ?
Is it considered at least a bug and can you correct it? A answer will be appreciated.
PostPosted: Sun 13. Sep 2020 14:32:00
I can confirm that this does the same thing for me. The Rescue time out does NOT work when RTH is active !! Heli just keeps going up.
PostPosted: Mon 14. Sep 2020 16:46:14
Thanks LogoX2 for confirming the issue.
Thomas,
Can i know when you expect to look at this issue ? Is this thread the right place to post a bug ? I usually see you answer and i see nothing posted so it is getting me nervous about being seen and addressed.
PostPosted: Mon 14. Sep 2020 18:27:30
I am not replying, because we are extremely busy.
Once I will be able to answer the question I will reply.
Thank you for understanding.
Unfortunately everybody expect reply as soon as possible. But to reply hundreds of questions each day is taking time.. My primary goal is to move development forward.
PostPosted: Mon 14. Sep 2020 20:02:30
Thanks Thomas !
PostPosted: Tue 29. Sep 2020 13:58:23
The issue will be resolved in upcoming firmware update.
It will be available within 1-2 weeks.
PostPosted: Tue 29. Sep 2020 14:43:24
Thank you very much Thomas !
PostPosted: Thu 22. Oct 2020 22:40:15
I tested both features at the same time and now, the rescue stops after the timeout in version 3.2. Problem solved !!
After a few test I pushed and had to use both and it worked, saved the heli...
Thanks Thomas
