It is currently Sun 24. Nov 2024 21:10:20
PostPosted: Sat 15. Aug 2020 17:51:36
Any reason why my preferred mount option is not supported?
I would be happy to have a vertical mount option available.
best regards
Alois
PostPosted: Sat 15. Aug 2020 22:38:45
each model has designed spot for gyro mounting. This mounting position is designed so to allow the best conditions for the unit.
Normally any such position is not recommended for a various reasons. For example because aileron axis can achieve the highest vibrations and overal acceleration. Model can do a very sharp movements in this axis. So placing unit in this way will cause to bounce it bigger than when mounted normally.
Also such position is very insecure.
PostPosted: Sat 15. Aug 2020 22:40:08
Also I hope you have not connected a Telemetry sensor at the EXT/RPM/E2 port. This will cause crash. E2 pin should be unused.
PostPosted: Sun 23. Aug 2020 10:55:59
Thanks for the information!
PostPosted: Sun 23. Aug 2020 11:04:11
Thanks for the hint, I noted the issue at another post.
You should put an explicit warnig to the instructions page, that other E2 pins must stay unconnected, otherwise a crash will result.
http://manual.spirit-system.com/index.php?title=SpiritRS_Telemetry
http://manual.spirit-system.com/index.p ... _Telemetry
PostPosted: Mon 24. Aug 2020 10:27:17
Yes, the warning is also at the wiring page.
