It is currently Sun 24. Nov 2024 23:25:01
[ 3 posts ] |
SnakeEyes
Posted: Fri 23. Sep 2016 8:40:05 |
Hi, I just found out that the gear ratio in governor settings is limited to 1:12.7. Gear ratio of the HSM800 mechanic is 1:13.83. And thats not the only one beyond that limit.
That means I can't use the Spirit Pro governor properly because I can't set it up correctly.
Please increase that range! Best regards, Thomas
Posted: Fri 23. Sep 2016 11:14:56 |
We will fix the problem soon. Right now you can use workaround that will work in the same way as if you enter the correct value.
You can simply change Sensor divider. Governor is using this only for RPM calculation, which is evaulated by Gear Ratio * Sensor divider.
If the result will be similar with other sensor divider and gear ratio, then result is the same. Let's say you have Gear Ratio 4.
4 * 13.83 = 55,32 5 * 11,05 = 55,25
This mean that 11,05 ratio will give you same result as with 13,85.
SnakeEyes
Posted: Fri 23. Sep 2016 12:07:46 |
Thank you very much, that will do for me!
[ 3 posts ] |
Users browsing this forum: No registered users and 5 guests |
