Login https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=882 |
Page 1 of 1 |
Author: | Kennyd [ Sat 12. Sep 2015 10:38:28 ] |
Post subject: | Login |
Hi I have just registered so I can pre order a spirit pro This would be my first spirit unit I'm not sure that I've registered correctly I had already added my home address so was a bit confused with to part that asks "Please assign an address title for future reference " I put in "kennyd" What should I have put in ? If I order with the above information will I receive my unit through the post ok ? Kind regards Kenny d |
Author: | zosek [ Sat 12. Sep 2015 10:41:31 ] |
Post subject: | Re: Login |
I put "zosek" in there and my unit came to my adress just fine. You should be ok as long as you put your correct adress in |
Author: | Kennyd [ Sat 12. Sep 2015 10:50:22 ] |
Thanks for that I'm looking forward to trying it out I have 9 heli's mostly on beastx , I hope it ain't to complicated for an old dog like me lol A big factor in buying a spirit is the help that is given on here , regards Kenny d |
Author: | zosek [ Sat 12. Sep 2015 10:53:17 ] |
I also made transition from beastx, i had some problems but mostly because i was overthinking everything too much. Allthough the manual is a little unclear from time to time, i think you'll do just fine, if not, there is a forum for questions. Tomas was really helpful with my problems, he's also quick with responses. Good stuff |
Author: | Coco66 [ Sun 13. Sep 2015 10:11:15 ] |
The address title is used in case you have multiple addresses, you can name them for a quick reference when selecting the one you want, can be stuff like "Home" and "Work". |
Author: | ZeXx86 [ Sun 13. Sep 2015 10:23:38 ] |
If we will see any problem with your address we will contact you so the package can arrive without any problem. Thank you very much for your interest! |
