Gaui X5 - Unknown motor KV - do I need to figure it out ? https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=6168 |
Page 1 of 1 |
Author: | Bladecrasher [ Sun 04. Aug 2024 16:41:26 ] |
Post subject: | Gaui X5 - Unknown motor KV - do I need to figure it out ? |
All my Spirit heli's are on governor mode and I have always known the motor KV during setup. The used Gaui X5 Formula I purchased has an unknown brand motor so no KV known. I set my Spirit Pro @ 3,000 max rpm in the setup and have 2250, 2350, and 2450 HS being reported by telemetry at 76%, 81%, and 86% throttle values after 3 gentle test flights. Should I worry about knowing the KV? If yes, is there a way to use math and the telemetry data while keeping the heli on the ground with light skids to backward determine the motor KV? Thank you. |
