It is currently Sat 05. Apr 2025 11:25:10
PostPosted: Mon 06. Feb 2023 22:19:37
Hi All. I've been practising my 450l in stability normal but decided to change to scale. When I changed via the Bluetooth and a mobile the tail would not hold even when I pushed the gyro up to -90%. In normal I had it fine at -60% but I'm not sure what is happening in scale stability and why it won't hold solid. Can anyone assist maybe. Am I going up the wrong way should it be lower than -60.
Ta
PostPosted: Tue 07. Feb 2023 3:44:16
Ta
From my understanding, Stabi Scale is Rate mode Only, not heading hold
In Normal Stabilization, heading hold is or tries to maintain on all control surfaces.
Maybe this helps
PostPosted: Tue 07. Feb 2023 4:37:51
So are you saying that I put my gyro back in to normal positive instead of negative as i had it for for stabi normal.
PostPosted: Sun 11. Jun 2023 7:44:43
Ta
for scale you should have i at around + 55-70% headhold. NOT negative side of the gyro
next i wonder is how did you set up you scale switch? did you go to CHANNELS and assignet a swith to STABI SCALE ?
then you go to the STABI Menu and put it in SELECT BY CHANNEL
if your heli was flying good before you put it scale then this should not make any difference for tail.. only cyclic/stability
unless you changed someting
PostPosted: Tue 13. Feb 2024 16:13:57
Is it possible to enhance tail authority in stability scale helicopters by implementing unconventional design modifications or utilizing alternative control mechanisms?
umek.pro insulator supplier
PostPosted: Sat 02. Mar 2024 2:27:11
Still having issues with the gyro. The heli is in scale stability mode and the gyro has been run from 40 to 75 and it doesn't seem to make any difference to the waging that is present. Any thing I might be missing anyone.?
Users browsing this forum: No registered users and 1 guest
