geo link problems https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=5553 |
Page 1 of 2 |
Author: | neils [ Sun 05. Feb 2023 20:12:50 ] |
Post subject: | geo link problems |
Today i tested my new build sab goblin 420 with geolink, when I switch on altitude limit ( safety net ) at about 4 meters the helicopter shoots up and does not stop ! I only just managed to switch off and recover. I have the same setup on my goblin 580 ie designated channel and state 1 with no issues. I have checked the setup several times but it still does it. Do i need to hover for longer before engaging ? |
Author: | ZeXx86 [ Sun 05. Feb 2023 21:32:58 ] |
Post subject: | Re: geo link problems |
Hello, there will be only problem in configuration. Please attach your configuration file and I will check it. |
Author: | neils [ Tue 28. Feb 2023 18:43:50 ] |
Today I tested my Sab 420 with Geolink V2, before the test I deactivated all functions on the geolink except for altitude level (ie the net ) but still the heli goes up and up without stopping when I activate the switch in state 1 I also test my Sab 580 today with Golink V1 with perfect result, no problems and yet same configuration . My setups are the same ! there must be a problem with geolink V2 I also have a Sab Genesis with Geolink V2 and this also goes up up up without stopping when i activate the altitude level switch. It appears Geolink V1 works good but not V2 Thanks for your help Neil |
Author: | Rider4490 [ Thu 23. Mar 2023 7:49:46 ] |
Hi all Same Problem here on both Geolink V2 and Spirit GTR as soon as i activate it on the Spirit GTR Geolink is off it Shoots up with no Stop. The same for GEolink V2 function turned off in the SPirit GTR Heli Shoots up with no Stop |
Author: | ZeXx86 [ Thu 23. Mar 2023 8:04:32 ] |
This can happen if more functions are enabled. Please unassign and disable all unused functions. Then it will work. Or you can send settings file and I will tell you what is wrong. Very likely there is stabi function. |
Author: | Rider4490 [ Thu 23. Mar 2023 9:09:09 ] |
Hey give me 10 minutes and i will sen you here both setting files from both soxos helis |
Author: | Rider4490 [ Thu 23. Mar 2023 9:16:38 ] | ||||
Post subject: | Re: geo link problems | ||||
This are the files from Soxos V2
Author: | Rider4490 [ Thu 23. Mar 2023 9:20:27 ] | ||||
Those 3 files are from the Soxos V1
Author: | Rider4490 [ Thu 23. Mar 2023 9:46:21 ] |
ZeXx86 wrote: This can happen if more functions are enabled. Please unassign and disable all unused functions. Then it will work. Or you can send settings file and I will tell you what is wrong. Very likely there is stabi function. unassigned all stabi funktions doesnt work |
Author: | ZeXx86 [ Thu 23. Mar 2023 10:09:17 ] |
Hello, I can see that there are almost all functions assigned. Because there is very high chance some function is engaged together with Altitude Limit I recommend this: 1. Unassign ALL functions from Special Functions in the General - Functions, leave only F: GeoLink Altitude Limit 2. Turn off ALL functions in the General - GeoLink - Aid Tab, except Altitude Limit. After this change I believe it will work well. Then when you will be sure it works as expected, add other functions. But make sure that all are disengaged - value 0 in the General - Channels. |
