It is currently Fri 22. Nov 2024 1:35:35
PostPosted: Sun 11. Apr 2021 23:15:43
Does anyone have the specs for the telemetry cable for a hobby wing v4 80a? My local shop just went out of stock and they are not ordering before they have a bigger order from spirit so I’m stuck without a cable..
PostPosted: Sun 11. Apr 2021 23:57:59
It is just Signal and Ground connection.
Do NOT connect Power Lead (5V)
Observer the lead swap at the Sat connector end.
PostPosted: Mon 12. Apr 2021 23:37:31
ok. The pictures are showing the red wire in both ends. Is it just not connected in the center piece with heatshrink on it? I notice the text also says to keep +5v out of it. So there is no level converter or anything inside that shrinkwrap?
PostPosted: Thu 29. Apr 2021 19:48:46
It's not connected in the interface cable. Remove it.
PostPosted: Mon 19. Jul 2021 20:58:31
I removed the red wire completly on my cable but I honestly can't see that the lead is swapped at SAT connector end. The picture in the wiki doesn't show them swapped? Could we make a basic drawing of this and upload it to the wiki so it's not confusing?
PostPosted: Tue 20. Jul 2021 1:02:27
Spirit 2, looking from the top of the unit with the text the correct way, the connection to SAT1 is:
signal / ground / no connection.
(orange / brown / no connection)
Users browsing this forum: No registered users and 47 guests
