It is currently Fri 22. Nov 2024 0:26:28
[ 2 posts ] |
MartyMcFly
Posted: Thu 20. May 2021 7:52:57 |
On the cable I use,I plug it into the s port on my frsky XR8 pro receiver,when I measure voltage comming out of s port it is 4.96v,when I measure voltage at red plug I am getting Zero voltage I presume that means the cable is faulty,many thank's for looking
Posted: Mon 24. May 2021 21:15:30 |
at the other side there should be zero voltage, because cable has electronics inside. At both ends there are different outputs. Unless cable is wired improperly it should all work. Otherwise it could be damaged permanently.
[ 2 posts ] |
Users browsing this forum: No registered users and 27 guests |
