Battery Backup https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=4689 |
Page 1 of 1 |
Author: | Dr.Fleming [ Sun 30. May 2021 13:23:54 ] |
Post subject: | Battery Backup |
Hi Tomas, why you not offer a Battery Backup System! I try the Optipower the Scorpion all this was shit. now I'm thinking to connect a 2S Directly to the Spirit, but I like to make some switch and fuse to it, what you think! |
Author: | latjo-k [ Tue 01. Jun 2021 3:53:54 ] |
Post subject: | Re: Battery Backup |
Hi why not use one of this? https://www.helistore.se/produkt/1st954 ... 4-8-3x50f/ //Latjo |
Author: | HeliMLM [ Tue 01. Jun 2021 7:06:45 ] |
... exactly THE solution you do not have to care about it anymore after installation... |
Author: | latjo-k [ Tue 01. Jun 2021 9:20:03 ] |
HeliMLM wrote: ... exactly THE solution you do not have to care about it anymore after installation... I have set the YGE bec to 8V and the alarm in TX (Jeti) to x<7V.That gives me abaout 1,5min to land when the alarm goes on. //Latjo |
Author: | Dr.Fleming [ Tue 01. Jun 2021 9:34:22 ] |
latjo-k wrote: And what about the reverse current ! |
Author: | HeliMLM [ Tue 01. Jun 2021 11:08:44 ] |
depends on your Esc if the reverse current is a problem... the buffer is great: peaks are handled, servo back emf is heavily reduced. with i.e. YGE there is no problem with buffering. if it is a problem with your Esc, there are possibilities to block the reverse current. |
Author: | Dr.Fleming [ Tue 01. Jun 2021 14:45:52 ] |
HeliMLM wrote: depends on your Esc if the reverse current is a problem... the buffer is great: peaks are handles, servo back emf is heavily reduced. with i.e. YGE there is no problem with buffering. if it is a problem with your Esc, there are possibilities to block the reverse current. Will Test it, thanks. |
