It is currently Sun 24. Nov 2024 20:26:14
 Post subject: Bec Current
PostPosted: Mon 01. Feb 2021 11:03:48
Hi
After install of new firmvare 3.2.2 and Jeti intergrationfile i test and display bec current.
Everything works fine,but on the bench whitout blades the log shows peaks of 40A when i move
all sticks together is this possible,the bec voltage constant 8.4V?
ESC YEG205HVT 12A/30A peak,Servos MKS HBL665 Futaba BLS 276.
Latjo
 Post subject: Re: Bec Current
PostPosted: Tue 23. Feb 2021 11:19:25
latjo-k wrote:
Hi
Latjo
Hello
After upgrade to V 3.2.2-r2 the bec current seems to be right.
I suppose that Tomas has done some correction in new firmware.
The sun is climbing higher and higher for each day now,soon there will be spring.
Happy flying
//Latjo
Users browsing this forum: Bing [Bot] and 1 guest
