Bec Current https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=4518 |
Page 1 of 1 |
Author: | latjo-k [ Mon 01. Feb 2021 11:03:48 ] |
Post subject: | Bec Current |
Hi After install of new firmvare 3.2.2 and Jeti intergrationfile i test and display bec current. Everything works fine,but on the bench whitout blades the log shows peaks of 40A when i move all sticks together is this possible,the bec voltage constant 8.4V? ESC YEG205HVT 12A/30A peak,Servos MKS HBL665 Futaba BLS 276. Thanks Latjo |
Author: | latjo-k [ Tue 23. Feb 2021 11:19:25 ] |
Post subject: | Re: Bec Current |
latjo-k wrote: Hi After install of new firmvare 3.2.2 and Jeti intergrationfile i test and display bec current. Everything works fine,but on the bench whitout blades the log shows peaks of 40A when i move all sticks together is this possible,the bec voltage constant 8.4V? ESC YEG205HVT 12A/30A peak,Servos MKS HBL665 Futaba BLS 276. Thanks Latjo Hello After upgrade to V 3.2.2-r2 the bec current seems to be right. I suppose that Tomas has done some correction in new firmware. The sun is climbing higher and higher for each day now,soon there will be spring. Happy flying //Latjo |
