Spirit System
wiring issue hook up
https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=3054
Author:  bingbongkev [ Fri 28. Dec 2018 6:00:50 ]
Post subject:  wiring issue hook up
Hi, I am having trouble trying to figure out what i need to order for wiring and how to hook it up .I am trying to hook up 2 dsmx sats a geo-link an external bec castle esc and a a wi- fi module + el/ ailx2 / rudder..flybarless. Also on a thunder tiger Raptor that has been converted to electric w/mechanical mixing what do i set the swash at in the menu 90 or 120 or? thank you for your time.,,,,,,,,,,,,Kevin
Author:  ZeXx86 [ Fri 28. Dec 2018 10:38:00 ]
Post subject:  Re: wiring issue hook up
Dear Kevin,
I recommmend to buy:
Spirit Pro
Spektrum Adapter V2 (connected at the RUD port)
Spirit GeoLink (connected at the sat port)
Spirit Wifi-Link
2x Y-Cable
External BEC will be connected at the AUX2 and optionally other port.
ESC at the AUX1 port.
In case that you want to connect the Wifi-Link then communication cable will be connected at the SYS port while powering cable to any free powering port.
Y-Cables would be connected at the AUX1 and possibly RUD port or other port (for example CH4).
But instead of Spektrum satellites I would recommmend a SRXL receiver which is single line. This would give you many free ports and eliminate all Y-cables, Spektrum Adapter and also make it safer.
For example this receiver: AR7700
That is all you will need.
Author:  bingbongkev [ Sat 29. Dec 2018 6:38:10 ]
Hi Tomas, I am a scale flyer and don't need 3d capability so would a regular spirit be good for a 600 flying on 6s ? its a raptor 50 electric. If I use the spectrum multi adapter w/geo-link in sat port I can probably do what I need to do. Does the multi adapter drop the voltage down or is it dropped in the spirit unit? for the satellites? Thanx again for your speedy reply and happy new year, hope you prosper in the coming year and keep up the good work.....there are skeptics in my club which use mostly ikon so i want to "enlighten" them to a better product with better support and a better price thanx again Kevin
http://www.phpbb.com/
