Save Changes with Bluetooth and Android App https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=290 |
Page 1 of 2 |
Author: | FalconX [ Tue 07. Oct 2014 10:13:00 ] |
Post subject: | Save Changes with Bluetooth and Android App |
Hi together, i use the bluethooth Modul on my Spirit System. Connection is fine with my LG G Pad and also with my Win7 laptop. The Problem is, using the android Device i can't save changes in the Spirit System. Is there any button to save changes to device or should it save the changes automatically? Every time i reboot the Device all changes are gone. Using the save button (unit) on the backup menue (Win-Software, Laptop) over bluetooth is working fine. Thanks Jens |
Author: | ZeXx86 [ Tue 07. Oct 2014 16:33:16 ] |
Post subject: | Re: Save Changes with Bluetooth and Android App |
Hi, mobile app include same button for saving the settings as our PC software. You can find it in context menu in the app. |
Author: | jimsair [ Tue 07. Oct 2014 17:35:39 ] |
I was confused by this as well. When using your android device and using the app, You must select the menu button on your phone (not a tab in the Spirit app) and a menu will pop up that will allow you to SAVE PROFILE TO UNIT. |
Author: | ZeXx86 [ Tue 07. Oct 2014 17:43:29 ] |
Indeed there are differences. Mobile app is designed for touch screen and small displays, while with PC you can do precise clicks. |
Author: | FalconX [ Sat 01. Nov 2014 11:59:43 ] |
Hi Guys, thanks for the answers. Unfortunately there is no Button on my LG G7 Pad. I readed that Android 4.xx Devices need the Button in the App. Other Apps like Chrome or You tube have the button with 3 Points in the upper right corner. The Spirit App hasn`t that Button or I`m not abble to find it. Someone any idea? Thank you for your help. Falconx |
Author: | ZeXx86 [ Sat 01. Nov 2014 22:23:24 ] |
Thanks for the info. We will try to sort it out as soon as possible. |
Author: | error414 [ Sun 02. Nov 2014 1:36:31 ] |
Hi, Do you have 3 dots in the lower right (sometimes in the left)? Check out the video |
Author: | FalconX [ Sun 02. Nov 2014 8:33:52 ] |
Attachment: Here is a screenshot, the button below are "back", "home", "last apps", and "dual screen" the lg hasn`t that menue button. I dont know how many other devices are like that. My problem is, the lg is my only Android device all others are IOS. Will there be a version for IOS devices? Thanks a lot Jens |
Author: | error414 [ Sun 02. Nov 2014 8:59:27 ] |
LG uses some custom panel and it looks like it ignores the command view "option menu" Check it out here if it helps http://www.androidpolice.com/2013/11/05 ... -software/ "Homescreen, Launcher, and Navigation" For greater comfort he probably I'll add that button to the application apologize for the trouble |
Author: | FalconX [ Thu 06. Nov 2014 22:06:44 ] |
Hi, it will be awesome if you can set the button into the app. I searched for apps wich remaps or add buttons but most of them don't work with the original rom. But its a brad new device and i don't want to flash the original rom. For so long i will wait and maybe you can add the button in a future version. Thanks for your help Jens |
