It is currently Fri 22. Nov 2024 12:19:56
[ 6 posts ] |
Tfmcnellis
Posted: Mon 17. Sep 2018 0:28:25 |
I currently use a very precise spirit level layed on the Spirit unit to level it before every flight. I use this because I use Normal Stabilization and rescue. They both work very well. My question is, how precise do I need to be?
drparker151
Posted: Mon 17. Sep 2018 0:47:42 |
Great question, I was wondering if the forward tilt of the Oxy skids affects Stabilization and rescue and if so, do I need to level it out during initialization. Then after the swash dance can I let sit with its normal rake before take-off.
Rufus
Posted: Mon 17. Sep 2018 1:09:44 |
I wondered the same thing,that's why I went ahead and bought the GPS,it takes the guess work out of the equation once you set it up. Rescue is activated automatically.
Sent from my SM-N950W using Tapatalk
Posted: Mon 17. Sep 2018 9:19:16 |
If model is within +/- 10° then all will be fine.
Tfmcnellis
Posted: Tue 25. Sep 2018 21:23:02 |
Does this mean that if I am within the 10 degrees the stabilization will be accurate/ level?
denis747
Posted: Tue 25. Sep 2018 22:57:30 |
Yes it will work ok. I have a trex 550x which has a 5 degrees nose down attitude due to the skids. Rescue still rescues perfectly vertically up.
Sent from my SM-G950F using Tapatalk
[ 6 posts ] |
Users browsing this forum: No registered users and 5 guests |
