It is currently Fri 22. Nov 2024 1:37:06
PostPosted: Mon 19. Jul 2021 16:27:16
I’m thinking of purchasing a Geolink module for my uSpirit-Oxy2 with DSMX sat and HW 25A ESC. Before I made the purchase, may someone know:
1. Is the Geolink module work with uSpirit—especially using DSMX sat?
2. If above is yes, because I know the DSMX sat and Geolink module would share the same SAT port, could it be done by using some splitter to share the SAT port on uSpirit to two devices (including power)?
3. From the manual it seems that when using Geolink you will lose ESC telemetry from sensor (which comes from P/E/A port). Is it true? Is there a way to use the Geolink and uSpirit’s Governor function (which needs ESC sensor input)?
Any suggestions appreciated. Many thanks!
Users browsing this forum: No registered users and 54 guests
