It is currently Sun 24. Nov 2024 18:18:23
PostPosted: Wed 20. Aug 2014 22:15:55
I see on your website the adapter listed as no more available. How do I connect the satelite receivers to the unit. I normally use two with vbar. I want to purchase your Spirit fbl unit but I am not sure if I can connect two Spektrum satelite receivers to it.
PostPosted: Wed 20. Aug 2014 22:24:40
Hello Marian,
thank you very much for the interest.
Cou can connect two satellites.
First directly to satellite port and second with optional Spektrum Adapter.
So for a secondary satellite you will need to order Spektrum Adapter too.
PostPosted: Wed 20. Aug 2014 22:31:55
ZeXx86 wrote:
Hello Marian,
But the adaper is listed on your website as no longer in stock which translates jako ze se uz nevyrabi... ja si muzu ten adapter udelat sam. mam doma nekolik originalnich Spektrum kabliku, potrebuji jenom vedet kterej spektrum dratek kam pripojit na servo konektor. Oranzovej, cernej a sedej. Prosim poslite schema nebo popis.
PostPosted: Wed 20. Aug 2014 22:58:04
There is a voltage regulator, so you can't make it easily.
Spektrum adapters should be in stock tommorow.
PostPosted: Wed 20. Aug 2014 23:17:34
I see... No problem I will order one. I am in Sydney Australia. Do you have a dealer around here?? Can you post to Australia?
PostPosted: Wed 20. Aug 2014 23:33:02
Perfect.
Yes, we ship worldwide for cca $4 - $7,5. There are some controllers in Australia right now :)
PostPosted: Thu 21. Aug 2014 0:35:47
ZeXx86 wrote:
Perfect.
That postage is for the Spektrum adapter only or the FBL unit as well. I am going to order both and give it a try on one of my helicopters !!
PostPosted: Thu 21. Aug 2014 0:46:46
The postage is for both.
