Save vibration analysis to Jeti radio possible? https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=2226 |
Page 1 of 1 |
Author: | curmudgeon [ Fri 15. Sep 2017 23:08:10 ] |
Post subject: | Save vibration analysis to Jeti radio possible? |
I understand that the Spirit Pro does not have flash memory, so it is not possible to save a full flight vibration analysis to the Spirit Pro itself. However, is there a possibility to save vibration analysis to the Jeti radio via telemetry for later review? |
Author: | Coco66 [ Sat 16. Sep 2017 7:47:36 ] |
Post subject: | Re: Save vibration analysis to Jeti radio possible? |
Well, with Real Time Tuning you can use a switch to activate the Vibration Analysis in flight. IT IS actually store in the Spirit and you can review it once landed (gets lost when you power off). Look for "In-Flight - vibration analysis from flight" in the manual here in the Diagnostic section: http://manual.spirit-system.com/index.p ... figuration |
Author: | curmudgeon [ Sat 16. Sep 2017 19:43:18 ] |
The limitation of In-Flight vibration analysis via the Real Time Tuning is that you can only capture one vibration moment per axis per flight. The intensity of the vibrations change depending on the maneuver being performed. I would like to view the vibration analysis moment to moment per flight. The Spirit hardware does not have the capacity to store vibration analysis moment to moment for a full flight, but the Jeti radio could store the vibration analysis for later review either via the radio or the computer. So, is it possible for the Jeti radio to capture the vibration analysis via telemetry? |
Author: | ZeXx86 [ Sun 17. Sep 2017 20:18:56 ] |
All our units have Flash memory, this is necessary to make it work. Actually Spirit Pro and uSpirit have 1MB of memory which is enough to store approx. 5 minutes of flight or even 3* longer if quality will be worsened. The problem is technical as the saving operation require special condition that can greatly interfere with normal operation - so at the moment we prefer to keep the performance in any case. There is theoretical possibility to make it work so doors are still open. Unfortunately Jeti or other radios have no capability to transfer such data so quickly. On the other hand you can log vibration level all the time which already works. |
Author: | Alyon187 [ Thu 15. Mar 2018 19:43:51 ] |
Rig your phone up to watch your tx while you fly. Just a thought |
Author: | curmudgeon [ Thu 15. Mar 2018 20:17:40 ] |
Please, elaborate. |
