It is currently Thu 24. Oct 2024 1:23:52
[ 6 posts ] |
kgnkazanci
Posted: Mon 09. Sep 2024 21:51:58 |
Hi there,
Is it possible to use GTR unit with a receiver, spesifically Frsky receivers?
Cheers Kagan
Posted: Tue 10. Sep 2024 8:07:15 |
Joined: Sun 09. Jun 2013 13:14:17 Posts: 992 Location: Plzeň
No, the units RS / GTR are only for Jeti transmitter (the Jeti receiver is built-in).
_________________ Spirit System (Spirit W1, RS & GTR & all the others) Spirit Wave & JETI DS 12 http://www.habada.cz
kgnkazanci
Posted: Tue 10. Sep 2024 9:01:36 |
Okay, I know this already, but the thing I wanted to know that if it's possible to make it by a firmware change or little bit tinkering ? Or is it completely impossible?
curmudgeon
Posted: Thu 12. Sep 2024 4:29:49 |
As I best understand it, the Spirit RS and Spirit GTR (the Spirit units with the antennas) are only compatible with Jeti radios, and one CANNOT connect an external receiver to them (Futaba, Spektrum, Graupner, JR, open source, etc.) to work with a non-Jeti radio. I don't know if this is a hardware or a software limitation. Perhaps this limitation may be do to some sort of legal agreement with Jeti. Interestingly, both of these flight controllers (RS and GTR) will accept the soon to be released Spirit WAVE receiver and work with the soon to be released Spirit WAVE radio, which makes me think this external receiver incompatibility is a software lock limitation and not a hardware limitation.
kgnkazanci
Posted: Mon 23. Sep 2024 19:01:44 |
I think it's definitely a software limitation, If you can change receiver type and then the port of the receiver changes accordingly, then it should be possible to make unit to listen receiver signal from a different place than a internal receiver. But probably it's about an agreement between Jeti and Spirit. If these units accepts Spirit Wave, then this makes me think that they may develop Spirit Wave together or Jeti may produce it for Spirit ? just thinking ~
HeliMLM
Posted: Tue 24. Sep 2024 6:34:51 |
it's simply all about the connectors - the rightmost 2 connectors (except the RPM pin) are not connected to the Spirit unit anymore on the GTR units, but directly to the internal Jeti Rex3 receiver (it's E1/E2/Ext). those are the ones used for external receiver connection on GT units. you simply run out of connectors....
_________________ cheers Michael
[ 6 posts ] |
