It is currently Fri 22. Nov 2024 7:05:29
 Post subject: Re: New user of spirit
PostPosted: Wed 27. Jun 2018 9:13:47
Hi Zoki,
I am sorry for delay, but I returned from trip now and I was unable to reply sooner.
Quote:
Do i need to hold switch until my heli come to normal position and release that switch
Yes, usually it is enough to hold it for less than second to recover horizontal position. But to recover good altitude, it can take a longer time. If you will release the switch, it will immediately return to a normal flying mode.
Quote:
Bank switch is for self level mode?
It can be used anytime you want to change settings when flying. It can be used for changing between Rescue, Stabilisation, Flying mode.
Quote:
I see on ch 8,9,10 is special1 special2 and special3
For what is that special 1 2 and 3
With this you can assign a parameter and change it from your radio when flying without need of accessing the software.
You can also engage some functions which you will select. It only depends on what is assigned. In this way you can for example tune all parameters very quickly to find the best values.
Basically all questions are always answered in the manual, so you can find more details also there.
PostPosted: Wed 04. Jul 2018 21:22:42
Can you provide more details?
If a servo is buzzing it mean it is under load.
This mean it hitted some mechanical limit or your mechanics is extremely tight in push rods.
In that case you will need a ball reamer otherwise also flight performance will be very bad.
PostPosted: Thu 05. Jul 2018 19:41:41
You can remove servo arms and see if it will stop.
Some servos are doing a noise even if they are doing nothing, but the most servos are completely silent if there is no movement and no load.
PostPosted: Sun 08. Jul 2018 18:12:13
No need to change anything in your radio after loading the Preset.
Throttle curve is correct for average pilots. But beginners might want to change it so it starts at 0.
No, you have to set Rescue for one bank which will be activated whenever you will want to engage the Rescue.
For other banks you can set anything else.
The most pilots are flying with just one stabilisation as they can't learn both things at the same but learn gradually how to fly.
If you are not confident I recommend just flying with normal flight mode and Rescue mode first - you will need to set Stabi/Function = Rescue.
Then all is ready and you do not have to set anything else in your radio.
PostPosted: Sun 08. Jul 2018 19:29:24
could be possible.
Set in Bank 0 the Funktion Rescure acro with 0% Rescue collective Pitch.
Set in Bank 1 the Funktion Recure normal with for example 70% collective Pitch.
Set the Gain over a channel from Transmitter. The Funktion should be always active.
Now you just need to switch banks with spring switch.
