It is currently Fri 22. Nov 2024 0:40:34
 Post subject: Spirit on 700 heli
PostPosted: Mon 20. Nov 2017 23:16:49
I would like to fly the Spirit on SAB Black Thunder 700 Sport. Does it work?
Or would it better to go with the Spirit Pro?
 Post subject: Re: Spirit on 700 heli
PostPosted: Tue 21. Nov 2017 0:50:30
It is my understanding that the regular Spirit will work fine on any size heli including 700 and 800 size. However, since the regular Spirit has fewer pins than the Spirit Pro, you will need Y-connectors to connect a servo and 2S/BEC power to the same pin. Also, for Spektrum satellites users, the regular Spirit has only a single dedicated Spektrum port and requires a voltage lowering adapter for the 2nd Spektrum satellite.
Users browsing this forum: Bing [Bot] and 45 guests
