It is currently Fri 22. Nov 2024 1:26:59
PostPosted: Fri 10. Nov 2017 2:13:55
I'm seeing if I can get my tail to hold solid on my agile 5.5 while running a low head speed. The only way I seem to be able to achieve it to hold in hard pitch maneuvers is to add a bit of revomix, because they have a low tail gear ratio.
On doing this The tail held fine, very slight movement in pitch pumps, but if I hover and pull the ele stick back I find that the tail drops, but it also drops to the left. It looks as though I am adding some left aileron. So I added a lot of expo to my tx and it still did it.
When I tried it I the bench I see the tail slider moved when I give ele or ail commands. Not heaps of movement but I think this is causing the issue.
Should this be happening when I've added revomix?
I am using the spirit pro, normally no revomix with a higher HS, tail is solid and it tilts straight when pulling the eke stick back.
Cheers.
PostPosted: Fri 10. Nov 2017 8:07:32
Yes, this is normal.
If you are seeing odd behavior, then the revomix value is probably too high. I recommend maximally value of 4.
But instead of Revomix you can always increase Pirouette Consistency which acts as revomix but naturally.
This could solve tail holding in low RPM.
PostPosted: Fri 10. Nov 2017 8:12:30
Ok I'll try that. Thanks
Users browsing this forum: No registered users and 58 guests
