Here is the file from the flight. I've gone over everything in the heli, Spirit and transmitter settings thoroughly and cannot find any reason for the incident. The motor and the esc soldered connections are not lose at all, I even cut away the heatshrink to be sure. All cables are secured and cannot move around in flight. I was only about 30 feet away from the heli at the time. I'm running a Hobbywing 100a platinum V3 esc. My head speed was 3250 (90%), I set the max Governor speed in the Spirit to 3600 on all 3 banks but I run 75%,85%,90% in in my transmitter. It's been working great before the update. I'm using 2 DSMX sats and a Spektrum DX9.
I didn't start the flight until 2 minutes into the logs. The first 2 minutes was me walking the heli out to the field and checking it over pre flight. The High Vibes and signal loss come when I hit the ground on my hard auto landing.
I was going to go back to the esc gov anyways until the autorotation bailout was working, But I could really use some help figuring out this one.
spirit-log-2015-10-07-173454.pdf [88.91 KiB]
Downloaded 55 times
