It is currently Sat 23. Nov 2024 8:05:00
PostPosted: Wed 04. Nov 2015 19:43:02
I've got my pro version set up and flying ok without gov ???????????
Any way it's time to set the RED version up
Problem is I want 2 sats to work so I've only got the aux and rud channels spare
But the second sat will only work in the rud channel so that only leaves the aux ch for
The power lead from my 6.6v life
It keeps referring to 2 power inputs to power the fbl unit but I've only got one
Believe me I've tried every option to power the unit with 2 inputs and y leads to take the second sat but the sat won't initialise on a Y lead and /or I've got no throttle . So it leads me to believe the sat can only go to the rud channel and power on a Y lead with throttle goes to the aux channel
So is 1 power lead via a Y lead ok and safe to fly
PostPosted: Wed 04. Nov 2015 23:20:17
you can connect secondary satellite to the RUD port only.
Throttle must be connected to the AUX.
If you will use Y-harness, you can connect battery to the RUD (second free Y-harness cable).
In this way, it will work without any problem.
If you will need second power input, you can also use second Y-harness in the AUX.
If you are using classic receiver connection, then there are two power leads so you are feeding the unit from receiver.
It is not safe to use only one port for powering.
Users browsing this forum: No registered users and 68 guests
