It is currently Sat 23. Nov 2024 1:12:17
 Post subject: [SOLVED] Stability mode
PostPosted: Sun 07. Sep 2014 1:57:17
Hi
I now understand the giro settings for bail out. Does stability mode still use the same setup, ie a - ve giro entry becomes the tail gain in stability or does it change the amount of stability given ?
Ritchie
 Post subject: Re: Stability mode
PostPosted: Sun 07. Sep 2014 7:46:02
it is the same, it sets the tail gain. The amount of control given during stability is set in the computer software.
Once there is bank switching you will be able to have different levels of stability set up to meet you needs.
PostPosted: Sun 07. Sep 2014 8:57:07
Is there a way to change it at the moment jman? There is a new member at the club who wants it badly, i tried turning it on with mine but the heli seemed even harder to control. It just wanted to do its own thing
PostPosted: Sun 07. Sep 2014 9:19:50
It is the stabilisation mode, where your helicopter steering is similar to coaxial helicopter.
You can set stabilisation parameters in the Stabi tab to behave closely to your needs.
PostPosted: Sun 07. Sep 2014 9:40:39
Is this the stick priority setting Zex?
PostPosted: Sun 07. Sep 2014 11:44:52
There are two parameters for the stabilisation - stick priority and direction control rate.
PostPosted: Wed 22. Jul 2015 20:03:40
zex is was sent to you, all is 90, swash is level and blades 0. in stabi mode heli drifts to right pretty hard, no vibes. what am I doing wrong blade 450x. John
PostPosted: Wed 22. Jul 2015 21:06:59
Does it drift immediately after spoolup?
You can make sure if the unit is mounted perpendicular (especially in aileron axis). If so, changing center of gravity will help - if possible move your battery or servo to the side where it drifts.
Is your swashplate in the horizontal position before spoolup when you activate the stabilisation mode?
PostPosted: Wed 22. Jul 2015 21:29:55
all is level,plug in battery on level table in stab mode then take outside and spool up drifts right and forward, can use trans trim slides to get pretty good. so if drifts move battery to right and back ?
PostPosted: Wed 22. Jul 2015 21:37:25
move cog towards drift or opposite, I use 3m gray 3sided tape is the white foam that came with it better.
Users browsing this forum: No registered users and 20 guests
