Spirit System
drfts right
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=778
Page 1 of 2
Author:  john1127 [ Thu 02. Jul 2015 2:27:18 ]
Post subject:  drfts right
Got it flying pulls hard to the right in srab mode wash is level, whats wrong, stabil but need left stick?
Author:  ZeXx86 [ Thu 02. Jul 2015 14:35:51 ]
Post subject:  Re: drfts right
when starting in the stabilisation mode it is recommended to start the helicopter on a flat surface.
If you will tilt the helicopter to one side for a while, it will remember it and will stay at this position. So returning direction can be changed even it starts in angle.
Author:  john1127 [ Mon 13. Jul 2015 18:55:17 ]
No on flat serface and swash level still drift, and piroets cant do cause drifts all over piro direction good HELP
Author:  ZeXx86 [ Mon 13. Jul 2015 20:03:18 ]
Can you measure vibration level in the software, please? Maybe the level is extremely high, so it can cause the problem.
Author:  Scott H [ Tue 14. Jul 2015 3:06:07 ]
Just out of curiosity, how do you level your swash?
Author:  john1127 [ Tue 14. Jul 2015 20:26:48 ]
90 arms level swash with leveler and 0 degrees on blades
Author:  Scott H [ Tue 14. Jul 2015 21:08:24 ]
Is there any chance that after you leveled it with subtrim in the software that you did not save the settings?
Author:  john1127 [ Tue 14. Jul 2015 21:51:27 ]
no but in solftware does it put servo to 90 and then use sliders to 90 arms
Author:  Scott H [ Tue 14. Jul 2015 22:06:59 ]
Well I think you are saying in the subtrim tab that the software locks the servos at middle position (90 - you call it) and so at that point your use the sliders to make sure the arms are exactly at 90 degrees to the swash.
My point was that you actually saved those settings, cause if you didn't than the servos would revert to the old position.
Seems like it's either the vibration (what heli is this again?) or a swash that is no longer level.
Author:  john1127 [ Tue 14. Jul 2015 22:13:44 ]
I saved them Its a blade 450x log doesn't say anything about vibes but tail does shake till take off speed
http://www.phpbb.com/
