Spirit System
Governor - motor soft startup
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=755
Author:  pexy [ Sun 21. Jun 2015 20:25:08 ]
Post subject:  Governor - motor soft startup
Am I right that the Spirit governor does not support a motor soft start and the soft start must still enabled in the ESC?
Thanks,
Pexy
Author:  ZeXx86 [ Mon 22. Jun 2015 8:52:33 ]
Post subject:  Re: Governor - motor soft startup
Spirit Governor fully supports soft start with all ESCs. You only have to configure starting point with Min. parameter.
Author:  pexy [ Fri 26. Jun 2015 19:58:08 ]
Thanks for your answer.
I'm not sure if you have understood my question: when I, for example, configure a Castle Creations ESC in "Airplane" mode, it does not soft start the motor. That is, when I switch from 0% to 80% throttle the motor spins up in a second to 80% which is not good for helis.
So, my question is does the Spirit ramp up the speed slowly, or must the ESC still run in Heli mode in order to soft start the rotor.
Thanks,
Peter
Author:  elfew [ Sat 27. Jun 2015 7:40:29 ]
Dont use airplane mod
Author:  btheli [ Sat 27. Jun 2015 13:51:55 ]
Spirit has it's own soft start and you are supposed to be able to use NO soft start in the esc (airplane and multirotor for example).
It sounds like you are bypassing the spirit soft start somehow. I think this will happen if the spirit does not see a throttle signal below 1250us. If it goes under that then soft start is activated. This is how autorotation bailout works, and mine is not yet working, so everything I just said might be wrong. Still working on this and governor issues.
Sent from my SM-G920P using Tapatalk
Author:  ZeXx86 [ Sun 28. Jun 2015 19:05:30 ]
To use soft start from the beginning you have to configure the range of your ESC so it will start from 1250us.
You can do so just by using Subtrim in your transmitter or by changing Min. parameter to for example -130.
http://www.phpbb.com/
