Low head speed on Synergy E7SE https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=752 |
Page 1 of 1 |
Author: | johncclayton [ Sat 20. Jun 2015 9:00:30 ] |
Post subject: | Low head speed on Synergy E7SE |
Hi Is anyone flying low head speed on an E7(SE) and also using a Spirit FBL? If so I'd be keen on hearing what FBL settings you are using as well as the size of main/tail blades. I'm targeting a range of 1100 (6S setup) through 1500 (12S w/low throttle signal value). So far I'm running 696 main blades and 106 tails but will be fitting 716 mains and 116 tails at some point. Engine is 4525-520. Thanks --John Clayton |
Author: | ZeXx86 [ Sat 20. Jun 2015 20:10:33 ] |
Post subject: | Re: Low head speed on Synergy E7SE |
Hi, I believe that there is no special settings needed. Only problem may be with the rudder settings, where you could need revomix little bit. |
