It is currently Fri 22. Nov 2024 19:28:44
 Post subject: update and now problem
PostPosted: Sat 06. Jun 2015 9:29:28
I am on helifreak, I have the set up guide and I am in this forum...And after update I have : your software version is not equal with firmware ! please update unit or your software to same one
I disconnected the battery like the guide but I can't go to wizard....I am very happy to becoming crazy ...
PostPosted: Sat 06. Jun 2015 9:55:30
You only have to update your firmware to the same version as your software. You can download it from our web page.
You can see both versions in the software. Firmware will be probably 1.1.0 and software probably 1.2.0.
I also recommend to verify new firmware before flashing as described in this guide:
viewtopic.php?f=20&t=690
PostPosted: Sat 06. Jun 2015 14:31:37
Thank's....I finally saw that you must update firmware AND software :idea: not very clear on the guide but now it seems OK.
Users browsing this forum: No registered users and 49 guests
