It is currently Fri 22. Nov 2024 19:42:52
PostPosted: Wed 03. Jun 2015 3:45:24
I am interested in adding the bt module. I have two Dsmx satellites. My aux channel has
My esc with the red wire disconnected. The rudder channel has a y-cable with the bec lead and the adapter for the second satellite. Where can I plug in the bt module? I could do another y cable and plug my esc into one side and the bt signal lead into the other ( both plugged into aux) but where do I get power for the Bt module? Thanks
PostPosted: Wed 03. Jun 2015 4:26:42
My apologies. I made a mistake in my above post. The signal lead of the bt module would go into the sys port. Could I then plug the power lead of the bt module into a y connector (the other half has the esc plug with the red wire disconnected and both plug into the aux port of sprit ). Will that work? Thanks
PostPosted: Wed 03. Jun 2015 7:26:14
Yes, it will work.
Connection scheme is in my acttachment
btscheme.pdf [38.8 KiB]
Downloaded 193 times
Users browsing this forum: No registered users and 37 guests
