Spirit System
Gov min/max range
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=702
Author:  scornflake [ Mon 01. Jun 2015 2:11:51 ]
Post subject:  Gov min/max range
I'm having trouble setting up the gov for Nitro on an N7.
Im using RJX as my throttle servo, FS0521HV.
The problem is I cannot tune the Spirit to give me 0-100.
If I get the min tuned so that it hits the low throttle stop on the engine, I can't get the max to hit the top throttle stop.
The servo stops responding once there's a > 20 point adjustment. i.e: I can't tune min below -80 and I can't tune Max above 120. In trying to do so, there is no longer further movement/adjustment occurring at the servo.
So far this means while I can adjust to get a correct zero/min throttle position, I can't get the high throttle set (it's quite a bit off, prob 5mm away at the carb itself).
Should I just adjust end points to counter this? If I do that will that confuse the gov in the Spirit?
Author:  ZeXx86 [ Mon 01. Jun 2015 8:15:31 ]
Post subject:  Re: Gov min/max range
you can change travel adjust in the transmitter freely. Then it should match fine.
http://www.phpbb.com/
