[SOLVED] hobbywing rpm phase sensor https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=696 |
Page 1 of 1 |
Author: | djhandz [ Sun 31. May 2015 6:47:31 ] |
Post subject: | [SOLVED] hobbywing rpm phase sensor |
Hi guys i would like to try the gov but am a little unsure on the voltage going in to the pit port. I am running a castle ice lite 50 using internal gov at the moment but going to try the spirit gov. I am using the internal bec at 5v please could someone explain how i conect this to my spirit. Am i right in thinking that if i connect the rpm sensor to the rudder port minus the signal wire and connect the signal wire to the pit pin i am good to go. Or do i need to put a step down on the signal rpm wire going to the pit pin? Hope i made myself clear thanks guys |
Author: | ZeXx86 [ Sun 31. May 2015 10:22:54 ] |
Post subject: | Re: hobbywing rpm phase sensor |
Hi, we have tested that with HobbyWing RPM sensor you can use 3.3 - 8.4V without any problem as power supply for the sensor. |
Author: | djhandz [ Sun 31. May 2015 10:27:30 ] |
Thanks does this mean i can just connect the signal wire from the rpm sensor to the pit pin and then connect the pos and negative of the rpm sensor to the rudder port |
Author: | ZeXx86 [ Sun 31. May 2015 11:15:11 ] |
Yes, it should work fine as we tested it. We have updated the manual right now. |
Author: | djhandz [ Sun 31. May 2015 11:49:31 ] |
Yes the way described here works fine and initial bench test look really good very easy gov setup excellent work tomas and the rest of the spirit team |
Author: | zosek [ Thu 10. Sep 2015 17:55:20 ] |
Hey, which pin do i connect the signal wire to? The one that is shown on the picture (middle one) or the facing towards inside of the unit (the one for the signal). |
Author: | Coco66 [ Thu 10. Sep 2015 17:57:04 ] |
In the Spirit ELE/PIT/AIL port, the RPM signal should go to the middle pin. |
Author: | djhandz [ Thu 10. Sep 2015 20:37:03 ] |
Yes middle pin |
Author: | zosek [ Fri 11. Sep 2015 6:43:53 ] |
Thank you both. I know the picture in manual shows the middle pin, but i was kinda worried, because on all other pins, the signal is the one facing toward the unit, and normally all + and - are connected, so i was afraid i'd conect signal to +, and you know where that leads |
