It is currently Fri 22. Nov 2024 19:44:55
PostPosted: Sat 30. May 2015 19:51:38
I have a new Spektrum DX7 Black Edition
with the AR8000 , Chase 360
can you help me for the setting.
PostPosted: Sat 30. May 2015 21:50:00
There is nothing special to set.
Only make sure that your Cyclic type in the transmitter is H1 (without mixing).
Cables can be connected in the way as described there:
viewtopic.php?f=20&t=427
Then you can start to connect servos,
elevator servo is always CH2
rudder servo is always CH4
aileron servos are CH1 and CH3 and can be swapped.
Users browsing this forum: No registered users and 36 guests
