Spirit-Jeti Ds16 issue https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=664 |
Page 1 of 1 |
Author: | bonkievan [ Tue 12. May 2015 4:24:48 ] |
Post subject: | Spirit-Jeti Ds16 issue |
Hi guys, A bit of info first- Heli - KDS Agile 7.2, HV servos DS16 Rsat2 running ex-bus Spirit FBL 2S Rx pack I have my Rx pack with 2 servo leads y-harnessed into two servo ports, ESC thr lead into thr Aux port, into the Spirit. Spirit bench setup complete. Issue- I'm trying to finish setup my Spirit using an Rsat2 but have hit a snag when trying to calibrate my endpoints in my CC160HV. First of all, I was getting no Throttle indication/movement on the Diagnostic page in the Spirit, so I changed to Channel 1 (from Unassigned) in the Gui. Then i could get my Throttle moving in line with the pitch bar. Great i thought, issue solve but no...same issue. I've moved the Tx end points in - out etc, as per Castle procedure but still cant get it to register endpoints??? I'm new to the Spirit and Jeti, so i must be missing something? Any help greatly appreciated. |
Author: | ZeXx86 [ Tue 12. May 2015 7:36:19 ] |
Post subject: | Re: Spirit-Jeti Ds16 issue |
Hi, where do you connected the ESC? I guess it is AUX port. You can try to use subtrim and move the throttle value little bit lower if normal calibration does not work. Also make sure that you have linear throttle curve from 0% to 100% in your transmitter and your throttle hold is inactive. |
Author: | bonkievan [ Tue 12. May 2015 8:15:46 ] |
Hi ZeXx86 Yes, throttle from ESC into Aux port. I've checked the Throttle Cut menu and there wasn't even a switch assigned yet, so inactive. Linear thr curves. |
Author: | ZeXx86 [ Thu 28. May 2015 12:52:51 ] |
Hi, sorry for delayed response. Did you found any solution? What is current state? |
