Bind issues with spektrum dx9 and spirit2 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6376 |
Page 1 of 1 |
Author: | Daza [ Fri 21. Mar 2025 7:50:21 ] |
Post subject: | Bind issues with spektrum dx9 and spirit2 |
Hello, I have done a search and tried some of the solution's on the site for binding issues and none have been successful. Here is what i have tried and still no solution. Normal bind with wizard to step 4 with dsmx and bind plug in ele/pit/ail port restart as required no flashing satellite. Normal bind with wizard to step 4 with a dsm2 and plug in sys port still no flashing. Tried a reset of the unit and firmware update the repeat the above still no flashing satellite. I tried one of the solutions that said put a bind plug in both ports (ail/pit and sys) to get it to a 22ms format, still no flashing satellite. So i still have not been able to bind to my radio. if any one can help that would be great. I am running a Spirit 2 with Geo link trying to bind with spektrum dx9 Regards Darren |
Author: | morrchew [ Fri 21. Mar 2025 14:40:54 ] |
Post subject: | Re: Bind issues with spektrum dx9 and spirit2 |
Keep transmitter 5 to 6 feet away when binding |
Author: | Daza [ Sat 22. Mar 2025 7:39:51 ] |
Satellite has to be flashing before i even worry about the binding the transmitter . The problem is i cant get it to flash for binding. morrchew wrote: Keep transmitter 5 to 6 feet away when binding
Author: | Mattes61 [ Sat 22. Mar 2025 13:22:36 ] |
Hello, do you have any spektrum receiver where you can connect an satellite ? If yes then you can bind your satellite to your transmitter independent to spirit - as a result you have an bound satellite to your transmitter and you can connect it to the spirit as usual - you need not bind again your satellite - Regards |
Author: | ZeXx86 [ Sat 22. Mar 2025 19:16:16 ] |
Make sure that it is plugged at the correct port. If you have GeoLink module enabled it will disable one SAT port. If you enable also ESC telemetry, it will disable second one (depending on selected type). To make it work you have to plug it all at the correct ports (and possibly turn off ESC telemetry). |
Author: | Daza [ Tue 25. Mar 2025 7:57:41 ] |
Thanks Mattes61, That worked, it is now bound to the transmitter, and working on the program. Appreciated the help. Darren Mattes61 wrote: Hello,
Author: | Mattes61 [ Tue 25. Mar 2025 22:31:31 ] |
Hello Darren, Nice that I could help you ! Best Regards Matthias |
