It is currently Fri 22. Nov 2024 19:07:16
PostPosted: Fri 01. May 2015 16:58:14
In the Spirit software, on the stabi tab, I need to set neg pitch on the slider in order to get proper swash direction for rescue. That works fine, but I am unable to set "negative" pitch for the stabilization mode. It remains on the "positive" side of the slider. Is this acceptable for my settings? Haven't flown it yet to test it, would rather ask and be sure.
And thank you for the Spektrum set up guide :D
Gaui X3
Spektrum Dx8
Gaui X3 / Spirit FBL
Gaui X5 / BX (Spirit on order)
Blade 180cfx
PostPosted: Fri 01. May 2015 17:08:31
for the stabilisation mode pitch settings is not necessary, because collective pitch is controlled by your transmitter input. So you are controlling collective with the stabilisation all the time.
In case of the rescue collective is controlled by the unit so it is reason why it must be configured properly here.
PostPosted: Fri 01. May 2015 17:13:48
Thank you for the clarification and amazing product support.
Looks like I'll be converting my other birds to Spirit!
Blade 180cfx
Users browsing this forum: No registered users and 73 guests
